Using Zorin 18 Pro. No matter my settings, unable to get WSJTX to communicate with Kenwood TS 590SG transceiver. This is for Ham Radio.
Any ideas?
Is it the communications between WSJTX and the serial port? Maybe a serial port driver or some other driver?
How did you install WSJTX? I have not figured out how to install it yet. Any tips?
Using Perplexity A.I. using Ubuntu 24.04 in the search criteria as Zorin 18 is a fork of it, it returns with:
" How to get Kenwood TS590SG to communicate with WSJTX on Ubuntu 24.04
To get a Kenwood TS-590SG working with WSJT‑X on Ubuntu 24.04, you need to set up CAT (serial) control and USB audio correctly in both the radio and WSJT‑X.
1. Ubuntu and USB basics
On Ubuntu 24.04, the TS‑590SG’s single USB cable presents:
A USB serial device, usually
/dev/ttyUSB0or/dev/ttyACM0for CAT. -
A USB audio codec, usually called “USB Audio CODEC” for input and output.
Steps:
- Plug radio into USB and power it on.
- Run
lsusband confirm a TI/Burr‑Brown or Kenwood USB audio and a USB serial interface appear.
- Run
dmesg | tailorls /dev/ttyUSB* /dev/ttyACM*to see the device name that appeared when you plugged the radio in.
2. TS‑590SG menu settings
Use one of the common working configurations from TS‑590SG/WSJT‑X guides.
On the radio:
Set CAT baud rate: menu 68 (TS‑590SG) → e.g. 19200 or 115200 (just match WSJT‑X).
Set USB audio as data input: menu 69 → USB (audio input for data).
Set data source: menu 70 → Rear (for digital use, per many FT8 setup notes).
Reduce USB input/output levels: menus 71 and 72 around 1–4 to avoid overdriving (Kenwood FT8 sheet uses default 4).
Use USB mode rather than DATA if you want full 3.4 kHz passband (DATA is limited to 2.5 kHz).
After changing CAT baud or key settings, power‑cycle the radio so the new settings take effect.
3. WSJT‑X radio (CAT/PTT) settings
In WSJT‑X:
- Open File → Settings → Radio.
- Set Rig to “Kenwood TS‑590” (or TS‑590S/SG if listed).
- Serial port: select
/dev/ttyUSB0or/dev/ttyACM0that you identified earlier. -
- Baud rate: match the radio’s CAT baud (e.g. 19200 or 115200).
* - Data bits/parity/stop bits: Kenwood defaults typically 8 / None / 1. Leave at defaults unless you changed them in the rig.
- PTT method:
- Preferred: CAT (simpler; no extra wiring).
- Alternative: VOX if you want to rely on audio VOX in the radio.
- Test: Click Test CAT; the indicator should turn green and the rig should respond (e.g. change frequency). Then click Test PTT, and confirm the rig goes into transmit.
If Test CAT fails:
Confirm user is in the
dialoutgroup (groupscommand); if not:sudo usermod -aG dialout $USERthen log out/in. -
Verify no other program (e.g. fldigi) is using the same serial device.
4. WSJT‑X audio settings
In WSJT‑X:
- Go to Settings → Audio.
- Set Input to something like “USB Audio CODEC” (the TS‑590SG’s USB audio).
- Set Output to the same “USB Audio CODEC” device.
Then:
With the radio on and tuned to an FT8 frequency, you should see the waterfall fill with signals if the input is correct.
Use the radio’s and WSJT‑X’s audio level controls to keep ALC at only 2–3 bars when transmitting, as recommended by Kenwood’s FT8 setup document.
5. Quick troubleshooting checklist
If the two are still not “talking”:
No CAT control:
- Check correct
/dev/ttyUSBx/ttyACMxand permissions. - Ensure baud rate in menu 68 matches WSJT‑X.
- Try toggling “DTR”/“RTS” options in WSJT‑X (set to “None” unless your setup specifically needs them).
- Check correct
No audio in WSJT‑X:
Confirm the Input device is “USB Audio CODEC”, not the PC’s microphone.
Confirm menu 69/70 use USB for data audio.
No RF or overdrive:
Use WSJT‑X Tune button and adjust PC output and menu 72 so ALC just flickers 2–3 dots as Kenwood specifies.
If you share exactly what fails (CAT test, PTT, or audio), more targeted settings (e.g. exact WSJT‑X “Radio” tab values) can be suggested."
