About touchpad issues
installed Zorin OS 16. After restarting the computer, the touchpad malfunctioned. It doesn't move, and the mouse pointer feels very stiff.
The computer is acer aspire3. By the way, restarting it again will fix it. However, if you start it again after a while, a problem will occur. The computer isn't very good, but it's still working comfortably. I don't think there are many performance issues. What could be the cause in such a case? Also, how can this problem be fixed?
Have you tried installing Touchpad Synaptics?
sudo apt-get install -y xserver-xorg-input-synaptics
Once installed, restart and test.
understood. I will try it tomorrow.
I've tried it, but for now it's okay! Thank you very much.
