Add Startup Applications
Hi there, it's been a while.
I must be spoilt on Plasma, because adding an app to startup is done within the native 'settings > autostart' section, and then selecting the app via the applications menu. I don't have to drill down manually to /opt, or /usr/bin or ~/snap or ~/.var etc.
Are these threads superseded in 2026 with something ootb that i don't see?
Gnome drives me crazy.
I think the easiest method is to install gnome tweaks
sudo apt install gnome-tweaks
and in gnome-tweaks you can select your startup applications at tab startup applications.
Crazy. But if that's what it takes to make gnome usable...
Thanks.
Just a side comment here.
This is where Gnome has/is consistently failing. If they had listened to Devs and users instead of taking the Microsoft approach of "We know best so we will decide what is best for "ease-of-use" (in other words take K.I.S.S. to a different place altogether that isn't).
I appreciate many concerns with the release of Plasma 6.8 ditching X11 (xorg). That is why I use PCLOS Debian "trixie" release which uses XLibre and a non-mainline kernel, Liquorix.
If you feeling risky at some point come try Wayland Gnome, i have been having fun, since the first day i installed it, and learning. (Doubting my decision sometimes)
And yes Gnome tweaks is by far the best tool for Gnome.
On the flip side Nextcloud (server) should start by itself, the client on the other had different ball game, the snaps have problems starting up, the native .Deb installs feel a little better integrated.
Good luck :slight_smile:
Wayland is still not prime time and being pushed/promoted by Red Hat (sic. IBM), in much the same way they forced systemd and pulseaudio to be adopted, as well as Flatpak.
Wayland is not good for users with Accessibility requirements, and not good for screen recording or online meetings.
Only to have said that: There is a Program preinstalled called Startup Applications. That, You can use, too.
I use Kubuntu myself (fairly recently switched to it). I like that it gets "major" updates roughly 6 monthly. I'm not a fan of bleeding edge rolling.
I don't like that i have to de-Snap it, but i like everything else so far. It will still have x.org until i think 27.04, because i believe Kubuntu will get the "last" 6.7 release with 26.10.
I'm excited about TuxOS's future - as they're switching to Debian Testing base in a future release. I haven't looked into it much, but from what i gather they'll use Testing, but they'll have a kind of "slowroll" release. I think that Debian needs a middle-ground between Testing and Stable. Testing, for my mind, is a little too aggressive (only about 2 weeks, depending on the package) between Debian Unstable and Testing. TuxOS, i think, will possibly push this back to roughly monthly releases.. which for my mind is still a bit too aggressive. I would prefer 3-6 month-ish cycle. But beggers can't be choosers.
Yeah, but it's terrible. You have to find the app binary (or copy/paste stuff from the menu). It's Windows-level-bad when you ask it to choose a different default app. I'm honestly surprised they haven't copied Plasma's approach, with a different GUI. Autostart is a pretty basic OS concept after all.
I understand why Plasma is dropping X (choices have to be made), but it does suck. As you say, it's not quite feature parity. But if dropping X allows them more hours to get that parity, then it has to be done. Note that Plasma 6.6 has LTS until 2029!
When does Gnome drop LTS for X?
Gnome dropped X at Gnome 50 release.
They already have with Gnome 50.
No such bleeding edge with PCLOS Debian. When software needs updating the simple update notifier turns from a white tick on a green background to a white bell on a red background.
You right-click and select show updates. You then get the options of Synaptic or simple CLI option (or details or Cancel).
The Plasma "trixie" edition good until June 2029.
Under Zorin OS 18.1 Pro there is already preinstalled the app Startup programs. There all apps can entered to be started during boot.
Yes - but this: Add Startup Applications - #9 by d-man
