Had you set up LVM? (Logical Volume Management)
que? i have no idea what that is..
Well, LVM and Backlight are the only errors shown.
Let's fix backlight for now, and watch to see if the problem returns.
In terminal:
sudo nano /etc/default/grub
Then on the GRUB_CMDLINE_LINUX_DEFAULT line, add
acpi_backlight=vendor
It may look like
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
If quiet splash
is all you have in there right now.
jeez you read all that?!!! bro,respect!
You crack me up, man
bro you earned you daps,accept them
yeah quiet splash is all i have hear
will let you know on next restart
Upon restart,it still behaves the same and I have to do the ctrl+alt+Fn9/10
This looks like what you describe, as well. Some say that changing out Nvidia drivers does the trick.
Others say using "nomdeset"... And others say they needed to reinstall gdm3.
Looks like a tricky issue to nail down.
The nomedeset did it the first time the nvdia you died how do I do it in Zorin?
sudo update-grub
Boom,it work!!thank you yet again!!
