How can i order this menu to alphabetical order?
I guess so. Because i was struggling with some issues earlier.
Make sure you verify the SHA256 checksum of your downloaded .iso.
Isn't that already in alphabetical order??
I suggest you do as zabadabadoo says. Check the validity of the SHA256 sum of the .iso you downloaded.
How can i do that? I'm really new to GNU/Linux things.
All the info is here:
Hope this helps:
Finally. Thanks a lot, I owe you.
