An utter over hyped rip off
I did try Dolphin among many others, but I think that I had problems with renaming files. Split pane & renaming were the common flaws in every file manager before I discovered Nemo. The one feature I'd like is that Nemo should remember its position when I close and reopen it, but it's a nice-to-have, not essential.
You might like the terminal alternative, Midnight Commander. Additionaly I think you can split panes in the KDE App Konqueror that I mention in the Unofficial Manuals for 15, 17 and 18.
If the WiFi goes out after suspending and waking your system, try this, works for me:
Thanks, bit I tried both of these and found them problematic. I think the problem was the inability to simply rename files in the straightforward way that I was used to in Windows, specifically in Zabkat's xplorer2 split-screen file manager, which I highly recommend for anyone determined to stick with Windows. Me, I'm done with it.
