Aorus B550i Pro AX WiFi not working
Hi again. I've been loving Zorin OS on my laptop enough to take the step and install it on my desktop as well. However, I've ran into a little bit of an issue in that the WiFi adapter is not recognised. I've looked around and I've seen that it's recommended to do sudo lshw -C network, and it shows up here as unclaimed. In fact the whole output (pertaining to this specific adapter) is:
*-network UNCLAIMED
       description: Network controller
       product: Wi-Fi 6 AX200
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:07:00.0
       version: 1a
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix cap_list
       configuration: latency=0
       resources: memory:fc500000-fc503fff
Can anyone please help me fix this? Cheers :slight_smile:
Hi, Zorin 18 is based on Ubuntu 24.04, so used this in my search criteria on Brave A.I. (Ignore all references to Ubuntu):
" The Intel Wi-Fi 6 AX200 is supported by the iwlwifi driver in the standard Linux kernel 5.15 and newer, which is included in Ubuntu 24.04 . If the adapter appears as UNCLAIMED , it is typically due to missing firmware, Secure Boot interference, or driver conflicts.
To resolve this, first ensure the linux-firmware package is installed and up-to-date by running:
sudo apt update
sudo apt install linux-firmware
If the issue persists, consider the following fixes:
  • Disable Secure Boot : In the BIOS/UEFI settings, disable Secure Boot, as it may prevent the unsigned iwlwifi driver from loading.
  • Reinstall Firmware : If upgrades caused the issue, reinstall the firmware package to repair corrupted files:
sudo apt --reinstall install linux-firmware
  • Update Kernel : If using an older kernel, upgrade to the latest HWE (Hardware Enablement) kernel via ubuntu-kernel or the Ubuntu Pro kernel, which includes updated iwlwifi backports.
  • Check for Conflicts : Ensure no conflicting drivers (like broadcom-sta-dkms ) are interfering. Remove them if necessary and reload the module with sudo modprobe -r iwlwifi followed by sudo modprobe iwlwifi .
If the hardware is still not recognized, verify the subsystem ID using lspci -nnk | grep 0280 -A3 to ensure the kernel module is correctly bound to the device.
Thanks for answering so quickly. I've tried all of these and it doesn't seem to work? I'm not sure what the output from lspci -nnk | grep 0280 -A3 is supposed to be, but I got the following:
07:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
	Subsystem: Intel Corporation Wi-Fi 6 AX200NGW [8086:0084]
	Kernel modules: iwlwifi
What should I try from here?
Got it working in the end, I just had to do a cold reboot (i.e. unplug and drain residual power by holding down power button, then plugging back in). Embarrassed I didn't think of this sooner to be quite honest :sweat_smile:
