Applications Menu Disappears When I Connect 2nd Monitor to Laptop
I have the Applications Menu (Gnome Shell Extensions) installed and working properly. But when I plug in my second monitor via HDMI, it disappears. BTW, the same thing happens with the Zorin Menu.
Thanks for any help!
Is the panel displayed on all monitors? This setting can be made in gnome extension manager or by right-clicking on taskbar -> Taskbar Settings -> Position -> Display on all Monitors
Thanks for your reply! Which helped me look at the Taskbar Settings again. I already had Display on all Monitors on. But further down on the Position tab I noticed that "Left box" was not marked as Visible. Once I clicked that on, the Applications menu returned! Hooray! Thanks! :slight_smile:
