Arma 3 Character will not stop moving ..HELP NEEDED
Using Proton wit this game , but no matter the fixes i have found i can not stop my character moving
usually on proton thats stuck input, not arma itself. unplug any controller or wheel, turn steam input off for arma 3 (properties > controller), and check sticky keys in accessibility. ive also seen a movement key get eaten under proton so tap WASD once each or try proton experimental / proton 9. if youve got a virtual gamepad layer or a handheld overlay, kill that and test again.
Agreed, likely stuck input device. Unplug/replug, and or restart game, or computer.
If not stuck input, cycle through the later proton versions. This is a somewhat common bug, where characters get stuck just running in a direction when you release the key.
I had this happen in the game "Greenhell", which uses Unity, and needed to change the proton version for that one game after I got tired of my character running right off of cliffs.
