Audio: dummy output
Hello Fellows,
I'm new on Linux and would like to see if someone could help me to fix this:
Audio and Mic are not being detected, unless I connect with some bt device, which is working very fine.
Here are some useful infos about my hardware:
System:
Kernel: 6.8.0-65-generic x86_64 bits: 64 compiler: N/A Desktop: GNOME 43.9
tk: GTK 3.24.33 wm: gnome-shell dm: GDM3 Distro: Zorin OS 17.3
base: Ubuntu 22.04 LTS Jammy
Machine:
Type: Laptop System: Google product: Blorb v: rev5
serial: Chassis: type: 9 serial:
Mobo: Google model: Blorb v: rev5 serial:
UEFI: coreboot v: MrChromebox-2503.0-1-g7c91af68dee date: 05/01/2025
Battery:
ID-1: BAT0 charge: 16.2 Wh (46.4%) condition: 34.9/47.8 Wh (73.0%)
volts: 11.0 min: 11.2 model: LGC KT0 AP18C8K serial:
status: Discharging
CPU:
Info: dual core model: Intel Celeron N4020 bits: 64 type: MCP
arch: Goldmont Plus rev: 8 cache: L1: 112 KiB L2: 4 MiB
Speed (MHz): avg: 1610 high: 2421 min/max: 800/2800 cores: 1: 2421 2: 800
bogomips: 4377
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel ports:
active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:3185
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 04f2:b667
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: Chi Mei Innolux res: 1920x1080 dpi: 142
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2)
v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.3 direct render: Yes
Audio:
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: sof-audio-pci-intel-apl bus-ID: 00:0e.0 chip-ID: 8086:3198
Sound Server-1: ALSA v: k6.8.0-65-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Intel Gemini Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:0c.0 chip-ID: 8086:31dc
IF: wlp0s12f0 state: up mac:
Bluetooth:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-9:4 chip-ID: 8087:0aaa
Report: hciconfig ID: hci0 rfk-id: 1 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address:
Drives:
Local Storage: total: 58.24 GiB used: 9.26 GiB (15.9%)
ID-1: /dev/mmcblk0 type: Removable vendor: SanDisk model: DA4064
size: 58.24 GiB serial:
Partition:
ID-1: / size: 36.24 GiB used: 9.24 GiB (25.5%) fs: ext4 dev: /dev/mmcblk0p4
ID-2: /boot/efi size: 598.8 MiB used: 24.4 MiB (4.1%) fs: vfat
dev: /dev/mmcblk0p1
Swap:
Alert: No swap data was found.
Sensors:
System Temperatures: cpu: 59.0 C mobo: N/A
Fan Speeds (RPM): N/A
Repos:
Packages: 1909 apt: 1897 flatpak: 12
Active apt repos in: /etc/apt/sources.list
1: deb Index of /ubuntu/ jammy main restricted
2: deb Index of /ubuntu/ jammy-updates main restricted
3: deb Index of /ubuntu/ jammy universe
4: deb Index of /ubuntu/ jammy-updates universe
5: deb Index of /ubuntu/ jammy multiverse
6: deb Index of /ubuntu/ jammy-updates multiverse
7: deb Index of /ubuntu/ jammy-backports main restricted universe multiverse
8: deb Index of /ubuntu jammy-security main restricted
9: deb Index of /ubuntu jammy-security universe
10: deb Index of /ubuntu jammy-security multiverse
Active apt repos in: /etc/apt/sources.list.d/mozilla.list
1: deb [signed-by=/etc/apt/keyrings/packages.mozilla.org.asc] https://packages.mozilla.org/apt mozilla main
Active apt repos in: /etc/apt/sources.list.d/zorin.list
1: deb Index of /stable/ jammy main
2: deb Index of /patches/ jammy main
3: deb Index of /apps/ jammy main
4: deb Index of /drivers/ jammy main restricted
Active apt repos in: /etc/apt/sources.list.d/zorinos-ubuntu-apps-jammy.list
1: deb Index of /zorinos/apps/ubuntu jammy main
Active apt repos in: /etc/apt/sources.list.d/zorinos-ubuntu-drivers-jammy.list
1: deb Index of /zorinos/drivers/ubuntu jammy main
Active apt repos in: /etc/apt/sources.list.d/zorinos-ubuntu-patches-jammy.list
1: deb Index of /zorinos/patches/ubuntu jammy main
Active apt repos in: /etc/apt/sources.list.d/zorinos-ubuntu-stable-jammy.list
1: deb Index of /zorinos/stable/ubuntu jammy main
Active apt repos in: /etc/apt/sources.list.d/brave-browser-release.sources
1: deb [arch=amd64 arm64] https://brave-browser-apt-release.s3.brave.com stable main
Info:
Processes: 287 Uptime: 29m Memory: 3.69 GiB used: 2.38 GiB (64.5%)
Init: systemd v: 249 runlevel: 5 Compilers: gcc: N/A Shell: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.13
Thanks in advance
You can take a look at this helpsite at "dummy output"
So this is a Chromebook? Zorin lite would probably be better for you.
An Advice first: It would be nice when You could set up in Your Forum Profile what Zorin Version You use. I see because of Your Output that it is the Gnome Version. But it would be nice for a better Detection.
Now to Your Issue:
  1. Did You try it with a Reboot? Maybe after rebooting Your Speakers and Mic are detected.
  2. If this is a fresh Install, did You already update Your System?
  3. I see that You are on Wayland. You could try it with switching to Xorg. To do that, go to the Login Screen (not the Lock Screen). Simply reboot for that. When You are on the Login Screen, click on Your Profile so that the Password Field appears. When it is appeared, You should see a Gear Icon in the bottom right Corner. Click on it and choose the Option ''Zorin Desktop on Xorg'' and then log in and try if Your Audio Stuff works.
  4. Did You take a Look in the ''Additional Drivers Tab'' in Software & Updates if there is a Driver offered?
  5. Did You tried Pulse Audio Volume Control? You can install it with the Terminal Command sudo apt install pavucontrol and after the Installation take a Look in the Output, Input and configuration tab of it.
I agree with what has been said, Chromebooks are low spec machines, and will do better with Zorin OS Lite. Here's the link to the download.
Sound issues with Chromebooks do seems common.
I did a websearch using: "Intel Celeron/Pentium Silver Processor High Definition Audio driver: sof-audio-pci-intel-apl bus-ID: 00:0e.0 chip-ID: 8086:3198 dummy output Ubuntu 22.04"
Several hits from that, but see little success in solving.
Some opinions that "no sound" could be due to kernel regression, so maybe a different kernel may support that device.
Only "solved" item I found was on Arch forum, so I don't know if that is applicable here on ZorinOS/Ubuntu. Here is the link anyhow: [SOLVED] Intel Celeron/Pentium Silver- no HDMI sound output option / Newbie Corner / Arch Linux Forums
If you boot your installation USB using "Try Zorin", does sound work then?
(I would guess not, but worth a try)
You could always purchase a (linux compatible) USB soundcard as a workround.
You could try to install ubuntu 25.04 or one of the mentioned distributions at github and then try it with this script:
