Hi. I have migrated from windows 11 to Zorin a month ago. But I simply can not get all 6 of my Asus zenbook S16's speakers working. Only the right channel is working. I have struggled for days, installed pipewire, tried re installing linux firmware, etc. No joy. Any advice, please!!
I have seen someone on LM forum with the same issue. Sadly no solution was forthcoming there. ref: https://forums.linuxmint.com/viewtopic.php?t=450343
Which kernel are you using?
Please post the output from:
uname -r
If it is a 6.17 kernel (There have been numerous reports of problems with 6.17 kernel) then maybe try booting a previous 6.14 linux kernel version.
Restart your machine.
At the grub menu, select "Advanced Options for Zorin"
then
Select a 6.14.. kernel generic version
boot with the 6.14 kernel and test effect.
Note that default kernel will remain as the latest version and that will be used next time you
EDIT: I just stumbled on this: GitHub - BNieuwenhuizen/zenbook-s16: My journey with the ASUS Zenbook S 16 · GitHub
Did You already tried Pulse Audio Volume Control? You can install it with sudo apt install pavucontrol
When installed, check the Output and Configuration Tab's for seting up Your Speakers and trying Audio Profiles.
