Hardware Model: Micro-Star International Co., Ltd. MS-7E59
Memory: 32.0 GiB
Processor: AMD Ryzen™ 7 9700X × 16
Graphics: AMD Ryzen™ 7 9700X
Disk Capacity: 1.5 TB
Software Information:
Firmware Version: 2.A40
OS Name: Zorin OS 18.1 Core
OS Build: (null)
OS Type: 64-bit
Windowing System: Wayland
Kernel Version: Linux 6.17.0-29-generic
Onboard Device
Reference Designation: Realtek ALC1220
Type: Sound
Status: Enabled
Type Instance: 1
Bus Address: 0000:78:00.6
after running updates to Zorin 18.1 my sound stopped working.
I have been building PCs since before IBM came out with there first PC, but I am new to Zorin.
Please help a tired old man.
Some quick suggestions to try from another “old” computer user relatively new to Zorin.
Look and see if there are any additional drivers available: settings/system/software updates then the settings cogwheel that appears after it checks for updates, then the additional drivers tab (it’s more well hidden in 18.1 than it was in 17!)
Perhaps try a somewhat older Kernel from the advanced option grub menu choice.
