Hello,any help for "Auto-Login"? I mean Login without password
It is easier to keep the normal login with password. When you use the auto-login you get password prompts from your browser each time.
When you enable automatic login you'll get errors about keyring. Here is shown what to do then. But as said, safer and easier it is not to use automatic login.
https://www.baeldung.com/linux/unlock-keyring-fix
You can disable locking the screen at suspend then you only have to enter a password after boot.
You can enable this in Settings → Users.
If you are on Zorin OS 18, I think that has moved to Settings → System → Users. Or, maybe it was Settings → About → Users ![]()
The Screen Lock setting is in Privacy & Security on Z18, at least that's where it is on mine!
Should be that:
But maybe the ''System'' Option Name depends on the used Language? In German it is System.
