Battery charging cap on laptop
hello guys i want to know that I have a lenovo laptop which has feature of not charging battery after 80% and use direct power to run laptop on windows , is there any feature in zorin like that and also is there mux switch on zorin os for getting graphical output on screen using integrated gpu and dedicated gpu . I searched on internet but didn't get anything ;
I assume you mean the Lenovo Energy Management "Maximum Battery Life" function, which run on Windows. The subject of limiting battery charging, to prolong battery longevity has come up before, but no equivalent linux solution was discovered at that time.
There would be a couple of Gnome Extensions for that:
In respect of power, check this out:
It would be interesting if anyone here has tested that.
