Battery saver
Is there any battery saver for zorin os ?
You can install TPM
sudo apt install tpm
Restart.
You do not need to launch or run any additional configuration.
If that is not enough, there are other power saving Settings Configurations you can set up...
Moved to General Help as thread is not a Tutorial.
terminal says unable to locate package
Wow... sometimes my own brain scares me... I typoed (thinking of different thing altogether while typing)
Let me try again:
You can install TLP
sudo apt install tlp
Restart.
it worked thanks
