/bin/plymouth not found.
I was installing sudo apt install hollywood
. Then after some time I decided to uninstall it. When I was about to do sudo apt remove hollywood
, I can't find the terminal, and the only thing I found was byobu terminal. So I executed the command of uninstalling hollywood. Then I restarted it and boom: /bin/plymouth not found in boot startup.
