Hi, my mouse runs on bluetooth but the bluetooth sometimes turns off (regardless of the battery). Thennn it can not be turned on again. Only by restarting.
@Post_Eric Hi and welcome to the forum. To help us help you:
Which version and flavour of ZorinOS do you have. e.g. Z16 Core, Pro or Z15.3 Lite etc...
Also what computer is it and the WiFi/Bluetooth adapter?
Just an idea here. Are you using Zorin 16? I've noticed that they've added an option to turn off Bluetooth to save power and this setting can be found under settings, then power. Perhaps turning this option off could make a difference?
