when i turn on my wiif the bluetooth disconnects with the connected device.
Can you please turn off your wifi and bluetooth. Then open a terminal and run
sudo service network-manager restart && sudo service bluetooth restart
Once done, turn on your wifi then your bluetooth and test.
If it is working, reboot and test...
no it didn't work. when i play something (video) while in connected to the wifi the sound through the Bluetooth device buffers and the device gets disconnected and when i turn off the wifi, the sound through the Bluetooth is working and doesn't disconnect
What does bluetoothctl list
run in terminal yield?
What is the output of rfkill list
run in terminal?
Does bluetooth show any errors?
dmesg | grep -i bluetooth
Do you have blueman
installed?
sudo apt install blueman
Does enabling bluetooth with Blueman retain functionality?
You might look at prajjwald's script to reset bluetooth when it acts up:
Had you checked the rfkill list?
0: hci0: Bluetooth Soft blocked: no Hard blocked: no 1: phy0: Wireless LAN Soft blocked: no Hard blocked: no
