I am using an iMac to run Zorin OS16 with XFCE (thanks to Aravisian). Before I switched to XFCE I had paired up a bluetooth speaker, which is still working fine. I want to install a bluetooth mouse but cannot find a bluetooth app or interface to do this? I was looking for it in the top panel next to wireless but it is not there. Can anyone advise me where to look. I have seen in previous topics that Blueman is recommended but I cannot find that in the Software Store and Synaptic gives the following message:
Hi Aravasian, I cannot find it in the Software store and Synaptic does not have it either (see initial screenshot at start of topic).
I can only assume my bluetooth speaker got connected while I was in Gnome (before the switch to XFCE) as it is clearly functioning ok and shows up in Pulse Audio when I switch it on. I just cannot find a way to pair a new device. Bluez was listed in the terminal when FrenchPress suggested I do an update and upgrade but I see no app in the Applications folder.
I changed the server and then restarted the computer. Once it restarted I put your command into a terminal and attach a screenshot of the negative result.
