Bluetooth stops discovering devices after inactivity (Realtek USB, Lenovo IdeaPad)
Description:
On Zorin OS CORE (based on Ubuntu 22.04/24.04), Bluetooth stops discovering any devices after a period of inactivity or suspend on Lenovo laptops using Realtek USB Bluetooth (0bda:4853).
Symptoms:
  • bluetoothctl scan on starts but no devices are discovered.
  • hciconfig shows the controller as UP RUNNING.
  • rfkill list shows no soft or hard blocks.
  • Rebooting does not restore Bluetooth functionality.
  • Only a full power-off (disconnecting all power) restores Bluetooth discovery.
Hardware:
  • Lenovo IdeaPad 1-15IAU7
  • Realtek USB Bluetooth 0bda:4853
Workaround / Temporary Fix:
  • Manually reload the btusb and related modules (btusb, btrtl, btintel, btbcm, btmtk).
  • Disable USB autosuspend for the Bluetooth module by creating /etc/modprobe.d/btusb.conf with:
options btusb enable_autosuspend=n
  • After applying this fix, Bluetooth becomes stable and continues to work even after inactivity.
Steps to reproduce:
  1. Connect a Bluetooth device (e.g., speaker or headphones).
  2. Let the system go idle or suspend.
  3. Try scanning with bluetoothctl → no devices are discovered.
  4. Only after a full shutdown and power-on, Bluetooth resumes normal operation.
Notes:
This seems to be a Realtek + USB autosuspend issue. Providing an automatic workaround in Zorin could prevent other users from encountering the same problem.
