Bluetooth Zorin 18.1
Bom dia!
Migrei recentemente do windows para o Zorin 18.1, mesmo sendo leigo neste sistema, acabei gostando bastante
Formatei o notebook e instalei do zero o sistema, fora a tradução de alguns menus, o sistema funcionou 100%.
Aproximadamente uns 30 dias de uso o bluetooth começou a apresentar problemas, corte nos audios, desligava os fones de ouvido etc.
Hoje apos desconectar seguidamente os fones, eu desativei o bluetooth, (menu, configurações, bluetooth, chave do bletooth) e este não ativa mais.
Utilizei o comando via terminal (bem interesante isso) sudo systemctl restart bluetooth, mas não obtive nenhum resultado
maiquel@MK02:~$ su fatuser
Senha:
fatuser@MK02:/home/maiquel$ sudo systemctl restart bluetooth
[sudo] senha para fatuser:
maiquel@MK02:~$ lspci
00:00.0 Host bridge: Intel Corporation Alder Lake-U15 Host and DRAM Controller (rev 04)
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-UP3 GT2 [Iris Xe Graphics] (rev 0c)
00:04.0 Signal processing controller: Intel Corporation Alder Lake Innovation Platform Framework Processor Participant (rev 04)
00:08.0 System peripheral: Intel Corporation 12th Gen Core Processor Gaussian & Neural Accelerator (rev 04)
00:14.0 USB controller: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller (rev 01)
00:14.2 RAM memory: Intel Corporation Alder Lake PCH Shared SRAM (rev 01)
00:15.0 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #0 (rev 01)
00:15.1 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #1 (rev 01)
00:16.0 Communication controller: Intel Corporation Alder Lake PCH HECI Controller (rev 01)
00:17.0 SATA controller: Intel Corporation Alder Lake-P SATA AHCI Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation Device 51bc (rev 01)
00:1d.0 PCI bridge: Intel Corporation Alder Lake PCI Express x1 Root Port #10 (rev 01)
00:1f.0 ISA bridge: Intel Corporation Alder Lake PCH eSPI Controller (rev 01)
00:1f.3 Audio device: Intel Corporation Alder Lake PCH-P High Definition Audio Controller (rev 01)
00:1f.4 SMBus: Intel Corporation Alder Lake PCH-P SMBus Host Controller (rev 01)
00:1f.5 Serial bus controller: Intel Corporation Alder Lake-P PCH SPI Controller (rev 01)
01:00.0 Non-Volatile memory controller: ADATA Technology Co., Ltd. SM2P41C3 NVMe SSD (DRAM-less) (rev 03)
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter
maiquel@MK02:~$
maiquel@MK02:~$ lsusb
Bus 001 Device 002: ID aaee:8367 Telink Wireless Receiver
Bus 001 Device 003: ID 0bda:567e Realtek Semiconductor Corp. Integrated_Webcam_HD
maiquel@MK02:~$
Nota, o bluetooth funcionou muito bem por alguns dias antes de começar a apresentar algum problema.
Como posso consertar esse problema?
Muito obrigado mpela atenção!
  • Is on the ''Additional Drivers'' Tab in Software & Updates a Driver offered?
  • Does Your System run in Wayland or X11? You can check that with the Terminal Command echo $XDG_SESSION_TYPE
  • Is Your System up-to-date?
  • What Kernel do You use? You can check that with uname -r via Terminal. When it should be 7.0, You could try it with going back to the older 6.17 Kernel. Choose on Startup on the GRUB Menu ''Advanced Options'' and there the one with the 6.17 Kernel (without Recovery Mode).
  • Please check Your Version of linux-firmware apt list linux-firmware in the Terminal
Boa Noite!
It would be interesting to know which version of bluetooth is being used with:
hciconfig -a
Do you have BlueZ and Bluman installed?
Also take a look here:
https://askubuntu.com/questions/144655/how-to-check-bluetooth-status-via-terminal
If you have BT5 or BT6 you may need to install additional packages via Synaptic Package Manager:
Images from my Tutorial here:
Good morning!
I imagine it was some kind of bug; the Bluetooth had been acting up like that for a few days, but today, when I turned on the laptop, it started working perfectly again. I believe it must have updated sometime over the last few days.
Thank you all for your help!
