Brasero DVD ISO
Hi,
I use Brasero to make an ISO of my DVDS but there is one problem the subtitles are very transparent and i want to have them non-transparent i looked at the options in Brasero but there is no option to change this how can i achieve this on Zorin OS?
Subtitles are determined by the system theme.
One thing you can do is set a custom gtk.css to handle subtitles.
Are you using a dark theme or a light theme?
