Zorin 18.1 Core installed on my Dell Latitude 5490 without encryption and both the keys and on-screen slider work perfectly for brightness control.
However, I want additional security for this laptop as I take it out & about with me, so I re-installed enabling the LVM encryption - everything functions as previous EXCEPT the brightness. The keys do not change the brightness (you see the screen notification at the bottom of the brightness going up and down) but the brightness does not actually change - it is at a low or possibly off setting. The slider also makes no difference either.
I have completed a software update and rebooted (turn it off and on!) but still the same issue.
Wayland
Firmware 1.38.0
Intel UHD graphics.
Long time linux lover, first time community poster. Be kind I'm not young anymore ![]()
Thanks all
