Hi everyone,
After I purchased Zorin PRO and downloaded .iso as well as software provided in tutorial for formating Flashdrive, after few tries and many many errors it finally says "Flash Complete" and after that my flash memory stopped working, computer does not recognize it anymore. I tried again with another flash drive and the same, I can't use those sticks anymore, I tried cleaning them trough cmd but nothing helps.
Any suggestions?
I need help with recovering my sticks back as well as installing system after
The command prompt?
Right click on the start menu icon and select "disk management". Do you see your flash drive listed? Windows does not recognise bootable USBs every time. Did you try booting with the flash drive into Zorin OS?
Even I'm also faced this problem. I have dual booted my laptop. Windows 10 and Zorin. After installing Zorin OS.
I have tried using cmd(DISKPART), but there is no result same problem arises. At last my friend @Tamil only said me this technique.
I Logged on to Windows 10. Download and run poweriso as admin and continue it as TRIAL then go to TOOLS --> Clean USB Drive after that format the PEN DRIVE. Now, the USBs running fine for me. I don't know maybe this will work for him also I'm thinking.
Steps:
Insert the flash drive into one of the USB ports.
After installation, run powerISO as an administrator. To do this, right-click on the powerISO desktop shortcut and click on Run as administrator. A confirmation dialog that says “Do you want this app to make changes to your device” will be displayed. Click Yes to continue.
When powerISO is opened, wait for 5 seconds and click on continue unregistered.
From the navigation bar, open Tools and click on clean USB drive…
I'm using this San Disk [ SanDisk is Western Digital's brand for flash memory products, including memory cards and readers, USB flash drives, and solid-state drives. The company was acquired by Western Digital in 2016 ]
I know when I bought some type pendrive from shop someone have problems and someone are good. It could be fabric fail production or over many years using pendrive just dieying like sdcard. Pendrive you can read/write some period time then they just died.
