Broken packages and other problems
Hello:
I have a series of problems, which I would be very grateful if you could help me to solve them:
  1. I have a broken package: xdg-desktop-portal.
    Is there any way to fix it?
  2. Also, sometimes I get indications that there are several files that are not needed, so I am suggested to use sudo apt autoremove to remove them. However, the last time I did this I had files deleted which then affected my Nvidia video card driver, any suggestions?
  3. As I am having a birthday, I decided to treat myself to a present and purchased the game Diablo 4. But, when I try to install it through Lutris (application through which I have been able to run several Windows games), it tells me that it is a Windows only game and will not allow me to play it. This is very striking to me, as I previously tested the beta of Diablo 4 and had no problems.
    Thank you very much
    Alexandros
Try 'sudo apt install -f' or 'sudo apt install --fix-broken' and see if that removes broken packages.
Had this happen, twice, so far. For that, all I had to do was go back into the 'additional drivers' section in software and updates and just re-install the Nvidia driver - for me, 535. After the last time it hasn't happened again.
The game, probably not any help but - have you enabled win support in Software? Should install Play on Linux as well, might help. Lutris is unknown for me; I've only used Steam in Zorin, and force played Halo Infinite lol worked. Have you also tried running just with Wine, no Lutris?
And Happy Birthday!
the sudo apt autoremove command is a good command to use, but should be used with caution and good observation. The terminal tells you what it is going to remove - so always, always scan the list before just typing in y and hitting enter.
The reason that autoremove can remove essential system files sometimes:
Autoremove only removes additional packages that are installed automatically (thus the auto part of auto remove)
and
if following after (at any time) that you intentionally removed a package that autoinstalled those packages as dependencies.
Due to this, you almost always can predict when autoremove may give you a headache, thereby avoiding said headache.
This is a strange one...
Have you installed zorin-windows-app-support?
