If I go to change the panel settings on the primary display - and select "Display panels on all monitors" ... It appears it uses the scaling from the primary monitor. Basically my main monitor I have 200% scaling and %100 scaling on the others ... The panels are double the size on the other monitors , than they should be.
I believe this is a bug.
