Can I run Zorin on a Razer Blade 14 laptop
I have been using Zorin for some time on an older Dell laptop which sadly left this world earlier this week. I have a Razer Blade 14 that currently has Windows 11 installed. I wondered if there are any known issues with running Zorin on a Razer laptop. Thanks in advance.
Looking at their website I assume your Razer Blade 14 also has AMD Ryzen etc listed there. Whilst AMD is usually supported by linux kernel, I am wondering if that configuration could be too new for the linux kernel that Z17.1 is using. You could give it a try, but may need to install a more recent kernel.
Looking at the spec for my specific model it gives this info regarding the processor:
Intel® Core™ i7-6700HQ Quand-Core processor with Hyper Threading 2.6/3.5 GHz (Base/Turbo)
Its an old model that has been maintained pretty well over the years.
You could do a websearch using "Razor Blade 14 laptop Ubuntu 22.04". There is some chat on Reddit, but not re your specific model.
Alternatively, burn a USB and boot to "Try Zorin" and see what you get.
Test power, fan and wifi. As from my reading, they seem to be mentioned in the past.
Thanks, I will give it a try.
