Me too! I installed zorin 17.1 alongside the old version so I did not loose any data or programs I was using. The only issue I have is that when I start my computer I get a "grup" listing and a black screen. After I type "exit" the screen is gone and my pc boots as it should. So, where did the "grup" screen come from?
By the way, on a personal note I was wondering if you live in the midwest i.e. Missouri. I'm from California, Cardiff by the Sea and have been surfering for many years. I now live and am retired in North Florida. Anyways, Thanks for all your help. You got me into the terminal environment and I will venture into it more. Have a great day!
Cheers!
Hi, I think you meant GRUB. What happens when you update GRUB via the Terminal?
sudo update-grub
I don't live in the US. I have some cousins in the US and distant relations. I live in the steel city of Sheffield UK. (I did help a retired community nurse in Florida using Jitsi but could only use chat element to help her reinstall Windows 10 after she had been sold a dodgy hard drive.
I ran the suggested terminal update and got the following:
sam@sam-VivoBook-ASUSLaptop-X571LI-K571LI:~$ sudo update-grub
[sudo] password for sam:
Sourcing file /etc/default/grub' Sourcing file /etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found theme: /usr/share/grub/themes/zorin/theme.txt
Found linux image: /boot/vmlinuz-6.5.0-26-generic
Found initrd image: /boot/initrd.img-6.5.0-26-generic
Found linux image: /boot/vmlinuz-6.5.0-21-generic
Found initrd image: /boot/initrd.img-6.5.0-21-generic
Memtest86+ needs a 16-bit boot, that is not available on EFI, exiting
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
Found Zorin OS 17.1 (17) on /dev/sda3
Adding boot menu entry for UEFI Firmware Settings ...
done
I'll see what happens when I start up next time. Thanks and have a great day! Cheers!
