Can Zorin be installed in other location than c drive?
Hi, can Zorin be installed in another drive other than c:? I installed it in my F drive and got the “Fatal: Could not read from the boot medium! System halted.” after running Zorin in VirtualBox.
VirtualBox location:
F;\Program Files\Oracle\VirtualBox
Zorin virtual disk image:
F:.VirtualBox
Zorin under Devices > Optical drive is not checked
Zorin vdi file Storage location is in the F;.VirtualBox
Yes it can I dual boot with Zorin and Win 10 .... Win 10 is on my C:/ drive and Zorin is on my D:/ .... sorry I know nothing about VirtualBox .... I sure someone else will be along shortly to help you with the VB .....
Can you label a linux partition in windows?
I don't think so or at least I couldn't that is why I had to take extreme caution when viewing my partitions in Win to be sure I didn't format my D:/ drive when I was setting up my dual boot .... if you can I sure hope someone tells us how to do it ....
thanks for your quick reply :slight_smile:
