Can't access to my hard-drive after fresh reinstallation
I was able to access to my hard drive before reinstallation, but now I can't access to my hard-drive on Zorin OS.
Says here: Error mounting /dev/sda2 at /media unknown error when mounting /dev/sda2
Is that drive formatted to NTFS or other?
I think so, mine Zorin OS used to be encrypted so I decided to do the fresh re-installation it. I can also access to my hard-drive on my windows laptop but the notification is telling me there's the error and telling me that i should scan it and fix.
You might try
sudo ntfsfix /dev/sda2
what would happens If I do this?
Nevermind.
That command runs essentially a file system check; similarly, you can run
sudo chkntfs /dev/sda2
There is a manpage you can read the manual:
https://linux.die.net/man/8/ntfsfix
and I halt here because you just posted "nevermind..." :stuck_out_tongue:
yeah cuz for some reason, it got automatically fixed on itself lol, But thanks though.
