Cant mount LDM data
hello
i'm trying to mount my HDD, disk program said it's a LDM partition, so i installed ldmtool, run the create command, but i got an error that said "Unable to create volume Volume1 in disk group 54e36f15-8d06-11e9-8229-9822ef5d3aee: ldm_vol_DESKTOP-UO0R25J-Dg0_Volume1: Stacking NODE_DEL [verify_udev]"
is there any workaround for this?
thank you
Are there any Data on the Drive?
yes
i was able to mount it before (different OS, kubuntu)
Hello,
Created with the help of ArchWiki
Try that
Remove any leftover mapping. Check for it with sudo dmsetup ls , then remove it:
sudo dmsetup remove ldm_vol_DESKTOP-UO0R25J-Dg0_Volume1
Mount and check. Once the volume exists, mount it read-only first to confirm the data is there before you write anything:
sudo mount -o ro /dev/mapper/ldm_vol_DESKTOP-UO0R25J-Dg0_Volume1 /mnt
hello, thanks for the reply
i tried the command above, but it give me this as return
sudo dmsetup ls give "No devices found"
sudo dmsetup remove ldm_vol_DESKTOP-UO0R25J-Dg0_Volume1 give "device-mapper: remove ioctl on ldm_vol_DESKTOP-UO0R25J-Dg0_Volume1 failed: No such device or address
Command failed."
is there any workaround i can try?
Can You plug in the Drive, open ''Disks'' and post here the Details what it shows please?
sda5 is where my data located
the gears to left ....if you click that is there a mount partition there?
If there is mount it then run the program you use to fetch that data and see if it sees it now
And the second command or what suggested @Ponce-De-Leon and @wesoliv429 ?
Hmm ... There isn't Windows installed on or is it? Please use the followin Command to check if the Packages are installed:
apt list libldm-1.0-0t64 libldm-common-dev libldm-common0t64 libldm-dev
You get a List with these Packages. Check if there is on each [installed] behind.
After you click on the cog wheel icon that @wesoliv429 mentioned, there should be an edit mount options menu choice.
You may be able to uncheck the default options and set up somethingthat works telling it where you want it to mount
there isn't
the command give me this
libldm-1.0-0t64/noble,now 0.2.5-1.1build2 amd64 [installed,automatic]
libldm-common-dev/noble 0.1.3-4build3 amd64
libldm-common0t64/noble 0.1.3-4build3 amd64
libldm-dev/noble 0.2.5-1.1build2 amd64
