I use OpenVPN that I run off of a Linode server. Unfortunately, I can't print any documents while my VPN is up. When I turn it off, I can print fine. I noticed there was a simple solution for NordVPN and I'm wondering if there is a solution for OpenVPN? Thank you so much for your help.
Thank you for this but I couldn't find a setting for "enable local LAN access."
