Cheapo 5.1 Ext. USB audio that does work
Hi there
In case you are looking for a cheap ext. audio card, I can conform the below two are working fine with 17.3 Pro, and without any need for extra drivers/software. Just plug'n'play.
Same thing..
https://www.amazon.com.au/Optimal-Shop-External-Recording-Compatible/dp/B07BGS2BS1/ref=ci_mcx_mr_mp_m_d_sccl_2_10/358-4879480-1757721
there are loads of like-alikes, at very different prices.
OR this one.
https://www.amazon.com.au/dp/B0CKPL5HXZ
better build Q, smaller unit, maybe a better noise floor.
The only thing to look out for is that the in-built mixer (alsamixer) does not label the 5.1 channels correctly.
CM-Audio
Cubilux
I had a nice internal 5.1 Envy24 sound card, but couldn’t get Zorin to play out the extra channels, so I resorted to the easy option.
Cheers CD
I found that Audacious plays decent 5.1 audio on your Z pc, using the above USB sound cards. Make sure set the output plugin in the Audacious settings to "SDL Output".
