Il n'y a pas de son sur mon lenovo slim 7 14ill10
I wonder if this may help: https://askubuntu.com/questions/1564315/headphones-audio-is-not-working-24-04-04-lenovo-slim-7-14ill10
Or that one may help:
- Do You use built-in Speakers or external one's?
- When You connect externalSpeakers or Headphones via Cable or wireless, do You get Sound?
- Is maybe a Mute Switch on Your Device enabled?
- Are Your Speakers listed in Settings>Audio?
- Did You tried Pulse Audio Volume control? It is a Tool for set up Audio Output and Input. You can install it with
sudo apt install pavucontrol
When I test left or right speaker I can see the cursor move in Puse Audio monitor but no sound
It worked ! I have sound ! I have been working more than a week on that...Thank you so much.
