Color messed up in external monitor
I have been using zorin os near two months with external xaomi monitor. which is working fine. Recently I bought lenevo l22i-40 monitor. After connecting with my laptop the colors of the new monitor are mismatched and they are not accurate. it's a laptop with AMD® Ryzen 5 pro 5650u with radeon graphics
zorin os 17.2
like in discord.com, the blue background turns out purple automatically, please help me out
Welcome to the forum!
I notice just by a quick google that this monitor appears to have both an HDMI port and a VGA port. If you are using the vga port, sometimes a vga cable goes bad and can be indicative of an issue such as this. Sometimes even unplugging and plugging back in can solve something like this, due to the nature of analogue cables instead of digital.
If you are plugged in via HDMI, sometimes you need to go into Settings and under Colour there should be a calibration option. Sometimes a standard calibration doesn't get set (although rare) so it's worth at least a look in there to see if something isn't adding up right there.
thank you. it worked after changing the color preset.
