Command shortcut(super+L) not working
i tried to customize my lock screen using lightdm and then i decided to keep the lock screen default so i uninstalled the lightdm
sudo apt remove --purge lightdm-gtk-greeter-settings
and now this Super+L is not working to lock screen but super+D is working fine
and even after uninstalling the lightdm the lock screen changes i have made is still there. How to reset the lockscreen customization
Are you using Zorin OS Core or Zorin OS Lite?
os core!
it got fixed now idk how tho
anyway do you know to set different wallpaper for different workspace??
idk why but its showing unsupported for walkpaper2 ....
i tried installing compiz But that didn't have that option to set for workspace1 and workspace2 so on
