I’ve been playing with a conky script, I have most of what I require on it now, mainly though trial and error, with lots of errors!
There is however some more information that I can’t seem to add, so I would like to ask for some help with this if possible.
Most important is to be able to see total capacity and free space on any USB device that I insert
Unfortunately I can only seem to get this to work with a full path to the USB device, like this:-
fs_used /media/chris/8A7D-AA77
which obviously is no use, as when I insert another USB device, it won’t have the same identifier
Is what I require possible, is there a “wild card” that can be substituted for the USB unique identifier?
I would also like to have running total of network traffic upload and download for the current log in session, also is it possible to get grid lines with values on the network graph, as the graph is pretty much redundant without relative values, the code I have for the graphs is ....
I have Core but your default software and procedures should be almost the same.
Click the button similar to this that you see on the taskbar when you plug a USB device > click either the USB device name or Open File > right-click the device name on the left panel > Properties. You can see used space on Disks and Disk Usage Analyzer, too.
Disks > click your hard disks > Unit Options (on the left of Minimize) > Data and SMART Test….
Thanks for the reply but I'm afraid you misunderstood what I was after, I was after adding that information to my conky app. I have the information now.
Just what I wanted, most grateful for the link to dynamically add the USB devices, many thanks for that.
I already had something similar to what you have for network traffic, what I was after was totals of network traffic, at least for the session, which I now have, I found another conky online which had this in, and I had to install vnstat, but now it is working.
I'm not sure if weekly and monthly will work though, they may be empty at present because I've only had this working for today so far.
I've attached a image for you to see it working and (blocked out the IP
