Connect External Display
I just installed Zoron os lite and i am trying. To install a external display but it wont work what do I do
What graphics card do you have?
Which driver are you on for that card?
sudo lshw -C video
Its a Amd Graphics Card specifically a radeon r7 m260x
For this card, you need radeon driver, not amdgpu driver.
Please relay the terminal output of
sudo lshw -C video
How looks Your Setup? I mean, is You Machine a Laptop with already built-in Display and You want connect a 2nd Screen or is it a PC with an external Monitor that doesn't run?
And how is the Display connected? HDMI? DisplayPort?
I am using a external dock to connect my laptop and that needed an exe
How do i install it
Can you give details (make/model etc) of that external dock and connections between the dock, laptop and monitor.
If an .exe was needed for the dock to run on Windows, then that will not work on linux. So it will be a case of finding out if the dock is, or can be made, linux compatible.
Doesn't Your Laptop have Display Connectors? If yes, try it without the Dock and see if it works. So, we can exclude that it is a common Issue.
This is information that should have been included in your Original Post.
And you are ignoring requests for information.
The members here cannot be helpful if your effort is so minimal.
I fixed it i used my display connectors on the laptop
I marked your last post as Solution.
