Hi. Is it possible to connect to Bluetooth devices from the taskbar? Every now and then I have to switch devices, so I often have to go to the settings and then to Bluetooth settings to switch devices. Can this be made simpler?
"Blueman", also known as "Bluetooth Manager" might provide you what you need. Open the "Software Center", wait a few seconds for the store to stop scanning for updates. Then type in the search box, bluetooth
and you should be able to find it.
Its highly regarded by our too cool for school moderator @FrenchPress and she I am sure will tell you all about it. I think it might provide option to add to the taskbar, as it is a fully featured Bluetooth manager, so should work awesome for you.
Wouldn't installing Blueman interfere with the the bluez on Zorin?
Okay. Will check it.
Which Gnome version should I select?
Gnome 3.38
Ok. Thanks!
