Hello , I'm actually building an app on Unity3D .
The problem is when I try to move my character using "Left" & "Right" arrow , the character won't stop after pressing the button 1 time ( it was normal when I was building the same app on Windows ). It's like there is continuous input.
Anyone got a fix ?
What is the output of sudo showkey
and pressing the arrow button?
It should have a release keycode.
If not, the only thing I could think of is looking for a BIOS update. Maybe the problem would have got fixed by the vendor... I didn't have any luck though on my machine with a similar problem.
Acpi handles much of the combination key presses. Does your keyboard have a function option on the arrow key? Is it a stock keyboard? Have you checked that you have the correct drivers installed?
Maybe:
sudo apt ubuntu-drivers autoinstall
If it's a desktop keyboard you could throw it in the dishwasher (top rack). Yes,
this is safe to do. Maybe compressed air?
I'm surprised to hear that suggestion. Surely if water damage was somehow mitigated by thorough drying, the dishwasher salt would still cause corrosion to the pcb.
It's a pretty common practice and is generally considered safe. But yes, the screws and any other metals may be subject to patina or corrosion.
My technique is more intensive: Disassemble the keyboard, first.
I wouldn't do it nightly or even monthly, but if you have a spill or whatnot, occasional washing will not hurt it.
