Copyq (clipboard app) not auto-starting with Zorin
Copyq (clipboard app) not auto-starting with Zorin. I'd like to see it open on startup, minimized in the tray.
Thanks folks
SOLVED: the solution is to put CopyQ in the Startup programs section of "tweaks" which I think is a gnome component I've had to add
sudo apt-get install gnome-tweak-tool
