Cryptsetup: ERROR nvme0n1p3_crypt newb help!
Hello!
I am asking for help as I got a new Thinkpad laptop and trying to install Linux for the first time and replacing Windows. I followed all of the instructions on this website and got to the very end where laptop restarts for the OS, however I have encountered the following:
Please unlock disk nvme0n1p3_crypt
I tried typing in the 3 passcodes I saved but only met with
cryptsetup: ERROR: nvme0n1p3_crypt, cryptsetup failed, bad password, or options?
So how do I access options? Do I need to reinstall the entire thing? Or should I try to set up Bios again? I will note that I did see there was 1 'error' scanned but did not see exactly what. What do I do??
Addition info: Hitting escape shows 'volume group "vgzorin" not found cannot process volume group vgzorin.
Edit: Figured it out! I was missing the Mok Management reboot which was not in the tutorial
So, Your Problem is solved, yes?
