Problem z uruchomieniem gier ! moze ktos wie jak to doinstalowac??? Zrzut ekranu z 2021-08-08 11-31-41|295x153
This warning means that your Graphics Hardware does not support Direct3D version 10.
You may need a newer Graphics card to run that game.
szkoda na windowsie z 3d nie bylo problemu grafa faktycznie nie jest najnowsza no ale jeszcze dosyc sprawna. ktore grafy sa lepiej wspierane na linuxie amd czy nividia chodzi mi o nieco starsze grafy
English translation:
it's a pity that on windows there was no problem with 3d graphics, it's not the newest one but it's still pretty good. which graphics are better supported on Linux amd or nividia i mean slightly older graphics.
I would tend to go with nvidia - you will need a bare minimum of a GT730 to run Zorin 16.1
