As the title suggests I deactivated my drive (Turned it off) in the Zorin OS app "Drives". I accidentally clicked on "Disable/Deactivate" with that little power button and now I cannot find an option to re-enable it? Where could I do so?
I tried sudo mount -a and sudo mount /mnt/DriveXY, which doesn't do anything. Also the drive still has an entry in /etc/fstab, so I'm wondering why I cannot re-activate it?
Why would you give the option do turn off a drive but not to turn it on again? Irritating.
