Does Zorin have a clipboard?
I copied some links and I want to know if i can retrieve them on vanilla Zorin OS.
Yes.
But to copy and paste text from one place to another you can’t do ctrl+C then ctrl+V. In linux it is ctrl+shift+C then ctrl+shift+V.
Or you can right click your selected text then use Copy from the menu, similarly Paste at destination.
Hi, I’ve never had such an issue in respect of Ctrl+ C (e.g., commands on a web page just so we are clear! - just pasting which is Edit | Paste when it comes to Terminal. :wink:
