Ok, but before i do the sudo nano thing, for future ref, can you show me how I go from the open root terminal to launching my preferred file manger please?
In the open terminal, elevate to Root:
sudo -i
Then in that same open terminal (Which should now show its home path as root)
Type your file manager name to launch it.
Zorin OS Core:
nautilus
Zorin OS Lite:
thunar
I use Nemo FM so:
nemo
oK, as easy as that. I have oft wondered how to do it -thx
Have deleted everything now save for the first line.
Now trying the PPA again.
Bingo, PPA is working- hopefully it should run smooth from here on it. Thx very much, as always, your sheer brilliance amazes me.
Just a thought though, when I do next use my proxy- - - have I beggared everything up there now?
EDIT UPDATE_ Unitootin is installed and working - ta very much
Wish I had known sooner that you needed that...
Add
export HTTP_PROXY="[username]:[password]@[proxy-web-or-IP-address]:[port-number]"
export HTTPS_PROXY="[username]:[password]@[proxy-web-or-IP-address]:[port-number]"
export FTP_PROXY="[username]:[password]@ [proxy-web-or-IP-address]:[port-number]"
export NO_PROXY="localhost,127.0.0.1,::1"
To your home ~/.profile
file...
Wish I had thought of it sooner~
Anyway, 'tis done, see what happens when next I light the Lantern.
Again, many, many thks.
P
Zorin did not like the change we made to profile, threw up a generic error. Reversed the changes, started fine. Will come back that later when I need Lantern next
Did you replace [username]:[password]
and [proxy-web-or-IP-address]
as well as :[port-number]
with the actual values rather than the generic stand ins used above?
No, that's why i took it out rather than fiddle with it.
I need to go back on line fire up Lantern and check their details and right now, I am short of time~
It was low priority.
I had this guy breathing down my neck to set up his machine.
But, we achieved my aim, so again, job well done.
Thanks
