"Dummy Output"
To start off, I have an HP 14 inch laptop model ep0000 with an Intel core i3-N305 in the Alder Lake-N architecture family, 8gb of ram, 256gb WD NVMe storage, integrated graphics, and Realtek HD Audio.
Currently it is running pop!_OS 24 and used to run Windows 11 and the sound works fine. It appears anything before Ubuntu 24 does not have sound drivers specifically for my laptop and I am really bummed about this because I really want to use Zorin OS on it. Going into a live disk, I can find in the settings that all I have is "Dummy Output". Is there anything I can do to fix this so I can use Zorin?
aplay -l displays "no soundcards found..." to start.
This is when I run uname -a and sudo lshw -C multimedia.
Summary
Linux zorin 6.8.0-40-generic #40~22.04.3-Ubuntu SMP PREEMPT_DYNAMIC Tue Jul 30 17:30:19 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
zorin@zorin:~$ sudo lshw -C multimedia
  *-usb:2
       description: Video
       product: HP True Vision FHD Camera
       vendor: Quanta
       physical id: 5
       bus info: usb@1:5
       version: 0.07
       serial: 200901010001
       capabilities: usb-2.01
       configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
  *-multimedia
       description: Multimedia audio controller
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 1f.3
       bus info: pci@0000:00:1f.3
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list
       configuration: driver=sof-audio-pci-intel-tgl latency=32
       resources: iomemory:600-5ff iomemory:600-5ff irq:19 memory:6001140000-6001143fff memory:6001000000-60010fffff
Feedback would be greatly appreciated to make things work.
Hi and welcome to the forum.
What are the results of:
sudo lshw -C sound
Thank you
This is the output of the command
zorin@zorin:~$ sudo lshw -C sound
  *-usb:2
       description: Video
       vendor: Quanta
       physical id: 5
       bus info: usb@1:5
       version: 0.07
  *-multimedia
       physical id: 1f.3
       version: 00
       width: 64 bits
       clock: 33MHz
See if this askubuntu thread helps:
This helped, thank you so much :slight_smile:
I always like to help where I can friend.
