Eidcard doesn't work
Since version of Zorin Os Core 16.2
Are there any problems with the Eidkaart reader?
tried everything, but doesn't work yet
Is there a solution for this?
regards
Faroud
Gday @faroud ,
Try here. may help.
Also run your updates, as new OS installs need to configure/update.
What updates do you mean?
was carried out from 16.1 to 16.2
General updates,
Do you have eID firmware? check for updated firmware.
