Wait wait wait yall.i just restarted again and changed from "zorin on xorg"to"zorin desktop"everything is back normal.thanks but could anybody please explain what happened
I dont know why but that xorg shii was causing problems and messing w my gpu.maybe due to it there were compatibility issues.its fixed but can anybody explain how and why
In the link I posted you first switching to Wayland was the solution for the yellow screen. But as this usually is not recommended for nvidia users in Zorin, I deleted the post. I really don't know why this helped you...But I'm glad that it works now.
Also my sys is still glitching and stuff.its still saying that my gpu does not support etc.soo what should i do
Brother i dont know why but my gpu compatibility issue still remains(it came out of the blue.
I aslo want to mention that i changed my driver through additional drivers>softwares and updates.now it says that its using x.org.xserver -- Nouceau display driver from x server......is this the cause of compat issue.hellllp meeeeee
Im thinking about re executing the commands aravisian mentioned.
What should i dooooo.the hue prob is fixed but compat and driver issue still remains
Hellppo meeeee
Yes, when there is shown that is Nouveau is used this is the cause for the warnings that your gpu is not compatible.
When you want to play games you need nvidia enabled.
Soo what should i do.try the aravisian command or choose one from software and updates
Unfortunately, I don't know the command for the nvidia driver version that worked for you before you changed everything (575 hashlite proprietary tested..). But perhaps you can select it at additional drivers? You should remove all installed nvidia drivers before with the purge command of Aravisian.
So i should execute all commands as aravisian said?
Hm..I'm a little bit confused what you have done.
Did you set Nouveau at additional drivers or happened this?
I was expecting the 575 driver to be displayed as the driver in use now.
Brother what happened was that i switched from xorg to "zorin desktop" then the hue fixed but checking the driver the xorg one was in use im asking should i change it.if so how
Sorry, I'm at a loss. If you know some drivers which run well on your system, choose them.
Use the purge command, then add the nvidia repository (the second command of Aravisian, but if you haven't removed the ppa, it should actually still be there), update your system and then click at additional drivers on the 575 hashlite driver that worked for you.
Brother thanks god.i chose a 575 proprietary nvidia driver.everything is working fine.noncompat issues.thanks so much.one last question.whats the difference between open kernel drives and normal.cause i chose the open kernel one.anyway thanks yall so much
