How do I enable FIPS in ZorinOS 16 installation? I tried installing Ubuntu Advantage package but it fails on Zorin OS.
The log file /var/log/ubuntu-advantage:
2021-12-08 18:31:35,911 - cli.py:(1528) [DEBUG]: Executed with sys.argv: ['/usr/bin/ua', 'attach', '']
2021-12-08 18:31:35,911 - util.py:(429) [DEBUG]: Reading file: /var/lib/ubuntu-advantage/private/machine-token.json
2021-12-08 18:31:35,911 - config.py:(523) [DEBUG]: File does not exist: /var/lib/ubuntu-advantage/private/machine-token.json
2021-12-08 18:31:35,911 - util.py:(429) [DEBUG]: Reading file: /var/lib/ubuntu-advantage/notices.json
2021-12-08 18:31:35,911 - config.py:(523) [DEBUG]: File does not exist: /var/lib/ubuntu-advantage/notices.json
2021-12-08 18:31:35,911 - util.py:(700) [DEBUG]: Writing file: /var/lib/ubuntu-advantage/notices.json
2021-12-08 18:31:35,911 - util.py:(700) [DEBUG]: Writing file: /var/lib/ubuntu-advantage/private/lock
2021-12-08 18:31:35,912 - util.py:(429) [DEBUG]: Reading file: /var/lib/ubuntu-advantage/private/machine-token.json
2021-12-08 18:31:35,912 - config.py:(523) [DEBUG]: File does not exist: /var/lib/ubuntu-advantage/private/machine-token.json
2021-12-08 18:31:35,912 - util.py:(429) [DEBUG]: Reading file: /etc/machine-id
2021-12-08 18:31:35,912 - util.py:(429) [DEBUG]: Reading file: /etc/os-release
2021-12-08 18:31:35,912 - util.py:(429) [DEBUG]: Reading file: /var/lib/ubuntu-advantage/notices.json
2021-12-08 18:31:35,912 - util.py:(710) [DEBUG]: Removing file: /var/lib/ubuntu-advantage/notices.json
2021-12-08 18:31:35,913 - cli.py:(1499) [ERROR]: Unhandled exception, please file a bug
File "/usr/lib/python3/dist-packages/uaclient/cli.py", line 1458, in wrapper
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/uaclient/cli.py", line 1544, in main
return args.action(args, cfg=cfg)
File "/usr/lib/python3/dist-packages/uaclient/cli.py", line 203, in new_f
return f(args, cfg=cfg)
File "/usr/lib/python3/dist-packages/uaclient/cli.py", line 166, in new_f
return f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/uaclient/cli.py", line 147, in new_f
retval = f(*args, cfg=cfg, **kwargs)
File "/usr/lib/python3/dist-packages/uaclient/cli.py", line 1107, in action_attach
return _attach_with_token(
File "/usr/lib/python3/dist-packages/uaclient/cli.py", line 999, in _attach_with_token
contract.request_updated_contract(
File "/usr/lib/python3/dist-packages/uaclient/contract.py", line 443, in request_updated_contract
contract_client.request_contract_machine_attach(
File "/usr/lib/python3/dist-packages/uaclient/contract.py", line 76, in request_contract_machine_attach
data = self._get_platform_data(machine_id)
File "/usr/lib/python3/dist-packages/uaclient/contract.py", line 276, in _get_platform_data
platform = util.get_platform_info()
File "/usr/lib/python3/dist-packages/uaclient/util.py", line 339, in get_platform_info
raise RuntimeError(
RuntimeError: Could not parse /etc/os-release VERSION: 16 (modified to 16)
